Please help ME before I RIP my head off!!!!
    Re: Please help ME before I RIP my head off!!!!
    The toilet will not drain after the 1st flush, and may overflow after the 2nd, but if I plunge it a few times I can get it to drain until the next time.
      When you run water, either the sink or shower does it path through the flange(where you can see water flowing by) or no?
      Proud To Be Union!!
        Let me check. I shall return in a jiffy.
          I think little timmy took Aqua man for a swim in the toilet.
          Does not sound like the main as showers are not backing up
            Ok, I'm back. I see nothing in the toilet flange when I turn the sink on, but when I ran the shower which is in the same side as the toilet the water in the flange rose up and down over and over.
              Too late to edit my previous post???
                Well, that could be, but it is 2 toilets, and I can't find anything in the one toilet that I pulled up. I want to pee in my toilet, ughhh!
                • #23
                  What happens when you run other drains on the other side of the house?
                  Is it making the water rise etc at the flange?
                  • #24
                    Gene, edit? uh, why? you were giving me some hope there!
                    • #25
                      Well, I don't see the toilet flange in the other bathrooms, but I do see some water movement in the working toilet on the other side of the house when I turn the sink on and off in there.
                      • #26
                        I'm gonna have to say the main line. At first I was thinking along the same lines as Gene until Ms. Fix It's report came back...
                        Proud To Be Union!!
                        • #27
                          The water rising up at the flange tells me the clog is not in the toilet.
                          It is somewhere in the pipe. So far from what yopu are saying it sounds like its just a short distance from the toilet area and not the main
                          • #28
                            How long has this been goin on? Did both just start acting up today? or has one been doing it for a while and now another one?
                            • #29
                              Do you think clogged toilets have a toy, or some other object in the flanges?
                              • #30
                                Nope. Ask yourself this, if there was a toy in the toilet, why would the water levels be rising and lowering?
                                Proud To Be Union!!
