Anti Siphon Hose Bibb doesn't work
  • Anti Siphon Hose Bibb doesn't work
    I have an Arrowhead anti siphon frost proof hose bibb that I just installed. Everything went great until I hooked up the hose. Water had flowed just fine through the hose bibb itself, but when I attach the hose it doesn't travel through the hose but shoots out through the siphon thingy. I tried another hose to be sure that wasn't the problem. What's up? Thanks,
    Kris
    Re: Anti Siphon Hose Bibb doesn't work
    Either the bobbit is misaligned, dirt is in the assembly or heat transferred and melted the plastic innards.
      6 lb sledge ?
      If it's fairly new return and exchange it.
        when you attached the hose, is there a shut off nozzle installed on the end? if so remove the shut nozzles and try again.
        arrowhead has designed and marketed a newer style anti-siphon bibb with yellow handle that flows 50% better and will not act up.
        i don't think they have them frost free yet.
          Thanks for the help....I got it working now.
            Bet she whacked it with a hammer
