Clean ,cleanouts
    Re: Clean ,cleanouts
    What about a cover that's stuccoed so it doesn't stick out and draw attention? What's an ibco?
      I'm da plumber,and do all My own stucco. Here's My thought. You know the stainless steel acess doors used for trap primers in commercial baths,for floor drains. I'll use one scuff it up and paint to match stucco paint. Steel would rust. Only problem, I have to weatherproff
      the door! The stuff Ido for RICH Ladys !!!
        Sounds like a great idea.
          ibco= iron body clean out.
          basically a fancy term for a female adapter used on waste that allows a plug to be screwed into it.
          a 4'' n.h. ibco uses a 3.5'' plug.
            what's the difference between that and a test tee?
              a test tee is a tee.
              an ibco fits at the end of the pipe.
              picture a female adapter.
              compared to a test tee.
                Plant a bush, or in Cali a cactus!
                • #23
                  Not code compliant in IPC.
                  • #24
                    Why?
                    • #25
                      ipc 708.8 cleanouts less than 6" need to have clearance of at least 18". I've yet to see a bush in front of a cleanout with this much clearance.
                      • #26
                        IBCO = Iron Body Clean Out , NOT EXPOSED, I know My customer . She has no idea about My plans for this.I am just thinking ahead. She likes what She likes. My Son will build a custom Two bowl french design vanity, drawn by Her interior designer. $11,000.
                        • #27
                          yeah i just go with the spartan access panel... and like the idea of a fo stucco texture
