Clean ,cleanouts
  • Clean ,cleanouts
    Have a bath addition with stucco siding. clean out cap will be seen from deck and dining room. Thinking of using a stainless steel acess door to keep it clean looking.
    Ever do this? Don't think this would be a code issue. Thanks' in advance Tool
    Re: Clean ,cleanouts
    You will think it is the only one that looks pretty. Why make it stand out? Why not use a IBCO/iron body cleanout or just a chrome cover plate over a flush mounted plug?
    It's on a wall, right?
    I love my plumber
    "My Hero"
    Welcome, Phoebe Jacqueline!
      Talk about an internet poser.
      SHEESH
        Right Joey. Stucco wall. I've worked for this Gal for years I have not poured footings yet ,just planning ahead. Thanks Tool
          SHEESH
          Whatever! You are just jealous I can change lives by day and be a plumber's wife by night!
          I love my plumber
          "My Hero"
            Once again your right Joey.
              We get along so well cause neither one of us has the hankering need to be right. so again I say. . .Whatever!
              I love my plumber
              "My Hero"
                Whatever....It takes to make it happen.
                  Joey, You are this forums ,Child Care Director!
                    How about just a steel access door painted to match, like what I see in hallways in hotels and condo buildings?
                    Or just bury it... most of the drywallers here seem to think that's acceptable (sigh).
                      An IBCO is going to need a san-tee behind it in the wall.If that wall is not a foot deep.Your configuration
                      is going to stick out far enough for Tool to tie his horse to.
                      Don't you think a clean-out tee would be better...JOERICKY?
                        Actually after mulling it over that's not that at all.
                        I just find the image of your hairy knuckles flying over the keys captivating.
                          joey is driving to work,
                          so i called and she explained her answer to me
                          the ibco would be good if the the line was an end of line c/o coming through a footing.
                          the chrome cover plate with flush plug is the choice in a 2x4/ 2x6 wall construction. this being screwed into the c/o tee/ test tee
                          call her adam, she'll explain it to you
                            She called me already this morning cause when she tried to say good morning to you,apparently you could not remember which planet you were on.
                            What are you talking about my 12grand rev friend.
                            The only thing one would screw into a clean-out tee is a plug.
                            Maybe YOU should call knuckles,maybe she can show you the light.
                              What ever you like for looks, go for it. Just make sure the c.o. is accessible. The plumber can't use what the plumber can't find.
