humming or buzzing noise when using the front garden faucet
  • humming or buzzing noise when using the front garden faucet
    Hi,
    I have a problem with a front garden faucet, when I turn on the water faucet to water the garden; I can hear the humming or buzzing noise coming from the faucet. This is a 2 story home. It is annoying, how can I stop the buzzing noise when ever I am using this faucet.
    Thanks!
    Re: humming or buzzing noise when using the front garden faucet
    it's either a loose washer in the hose bibb stem or a vacuum breaker that is pulsating. assuming you have an anti siphon vacuum breaker.
    does it happen with no hose attached?
      What happenned to the other thread of the same context where two other plumbers answered this question.
        Our answers werent important enough to pay attention too!
          Sorry, I will not be able to tell you that until I return there in two weeks.
          I will test that out when I am physically there.
            Thanks for the suggestion. I will definitely check that after I return in two weeks.
