Discontinued kohler toilets
  • Discontinued kohler toilets
    does anybody know how to find a discontinued kohler toilet bowl? I put one in that was defective and now need to order an entirely new toilet, but would really like to find the old bowl. It is a Kohler K-4257 Memoirs design. Any hints will help.
    Re: Discontinued kohler toilets
    I googled the part # and found one right off the bat
    http://http://www.plumbersurplus.com...=2&cvsfp=46535
    hopefully this works I am not that good at this posting links stuff
    seems like there are more sites you can find it at or you can check with different plumbing supply companies in your area and see if you can locate one
      good luck---hope u learned ur lesson----kohler is junk
