8" Copper
  • 8" Copper
    OK i have a job where i have an 8" water main going through a building. i am using 8" MJ DIP outside and specd 8" FJ DIP inside. The GC/Client wanted to know if we could use 8" copper insde because tgetting 100' of 8" ductile iron into this basement isnt really very easy to do. My question is has anyone ever seen 8: copper and if so up to what size have you seen. The GC's thoughs are the lower cost of labor will offset the high cost of copper. We are still in the planning phases of this job, there is no plumber lined up yet
    Re: 8" Copper
    No. I have not. At that size and price I wouldn't even look for a distributor. I'd call manufacturers. Might need a translator though.
      Re: 8" Copper
      ok, mueller makes 8" copper, list price is 522.82 a foot! so lets see, 100' long run that is $52,282 just for the pipe! Problem is I cant find 8" Victaulic flanges for copper! Whatever they decide I'll make sure to post some pictures. Funny the 8" FJ DIP is probably only half the price and twice the labor! I think I would go with copper, what do you guys think?
        Re: 8" Copper
        Honestly Wrench, out of my realm of knowledge. But interested to learn what you/they decide and why.
        Seems like ductile would get the job done at a lesser cost.
          Re: 8" Copper
          I am not a plumbing expert.
          I have no knowledge of 8"copper.
          I have layed miles of ductile Iron.
          What is the major labor involving using DI? Getting it into the building?
            Re: 8" Copper
            biggest i've ever worked with is 6'' type l. always brazed it as we t-drilled the tees. only thing we soft soldered was the bronze flanges.
            i still have fittings
            now on the big stuff, i use victaulic roll grooving for it.
            biggest mistake was lifting a 20' length and trying to make a turn and then put it down without dropping
            back then 6'' l was $20.00 a foot.
              Re: 8" Copper
              You might consider 8" stainless..comes in 21' lengths but can be cut outside. Vic makes 8" stainless fittings, but you'll need a special roller. Believe it or not SS is now cheaper than copper. In my opinion Vic'ing copper is a PITA, stainless rolls nice and gives plenty of rigidity at the joints
              West Trail Mechanical Ltd
              www.westtrailmechanical.ca
                Re: 8" Copper
                My bad, the fittings for SS are not actually made of stainless, they're a galvanized Ductile Iron. Good up to 300 PSI , available up to 12"
                  Re: 8" Copper
                  Round here you ca get copper up to 250mm (10inch)in 6 metre (20foot) lengths no problem. Its expensive as you note.
                  Easy to silver braze, form branches etc.
                  Surely there is a plumber familiar with that kind of work near your job?
                    Re: 8" Copper
                    just a thought,
                    how 'bout running 4" x 2 or x3 runs parallel to each other? just wondering.
                      Re: 8" Copper
                      The labor with the DIP is getting it into the building down stairwells etc and lifting it overhead to hang it from the ceiling. There are no brancehs or fittings coming off the pipe it is just straight for about 100'. IMHO it should take only about 2 days to hang all this pipe and install it with copper. I was thinking almost a week to hang and install the DIP. Using this idea I almost thing that the copper would be cheaper.
                        Re: 8" Copper
                        wrench, check your pm
                          Re: 8" Copper
                          If your going through the building with the water line, I assume you already need to core a hole. Could you maake it a bigger hole and pass the pipe through?
                            Re: 8" Copper
                            Check with Gilmour Supply in Mt. Vernon. (914) 662-2900
                            Or Davis and Warshaw in Maspeth L.I.
                              Re: 8" Copper
                              Thanks guys all is good. GC did a quick value engineering summary and determined that the 8" copper is the way to go. Appreciate all the responses and help!
