Laundry Vent
  • Laundry Vent
    Hi All.
    I'm new to this forum. I just moved in to this house. I thought that the laundry vent looked strange. I was hoping someone could tell me if this laundry drain was vented properly, or do I need to call someone.
    I've attached a pic.(I think) The pipe in the foreground is 1.5" to a sanitary tee. going into a 2" drain. I hope I explained this right.
    Thanks in advance.
    Re: Laundry Vent
    Can't vent it that way here but.... should be ok. You having problems?
      Re: Laundry Vent
      WHOA , Am I looking at a 2" stand pipe with NO trap! And what's the height?
        Re: Laundry Vent
        Look behind it. tool-it has a trap at the bottom. Are you having some sort of problem?
          Re: Laundry Vent
          Aggravating people.
            Re: Laundry Vent
            Why does it look strange to you ?
              Re: Laundry Vent
              IPC, it's perfectly legal.
                Re: Laundry Vent
                i would use a wye and 1/8th bend or combo instead of the san tee
                  Re: Laundry Vent
                  Originally posted by Jackapatt View Post
                  Hi All.
                  Thanks in advance.
                  Heya Jack from a fella Bostonian ...it's fine.
                  The 2" drain is in fact very good, our code only requires 1-1/2" for a laundry.
                  The distance from trap to vent has to be 2 times the diameter plus 2 converted from inches to feet.
                  In other words, 2 times 2" plus 2 equals 6'.
                  That vent is well within 6'...the ONLY thing I could pick at is the Tee-wye on it's back..it really should have been a wye + eighth bend (combo wye).
                  Most inspectors wouldn't really pick at that though.
                  Good luck with the new home...you picked an EXCELLENT time to buy in Boston.
                    Re: Laundry Vent
                    Thanks for all the responses. No I'm not having a problem, I just don't wan't one.
                    Thanks again.
                      Re: Laundry Vent
                      With that long of a tailpiece?
                        Re: Laundry Vent
                        I think you meant standpipe, no more thaN 28" on a laundry here.
                        24" on everything else.
                          Re: Laundry Vent
                          YES I AM,I'M STUPID! Just saw the clean out plug on the trap! You don't see them here much.
                            Re: Laundry Vent
                            [QUOTE=DuckButter;180291]Heya Jack from a fella Bostonian ...it's fine.
                            The distance from trap to vent has to be 2 times the diameter plus 2 converted from inches to feet. If code back there is 1 1/2" , do You still go 2" for a better performing drain!
                              Re: Laundry Vent
                              The question was not directed at you at all. Just the OP.
                              Here the IPC interpretation is:
                              Laundry box 35" above the finished floor.
                              Minimum 24" drop to trap weir. Maximum 48".
                              No san. T's on their back or horizontal drainage period.
                              NO DRILLING HORIZONTAL OVER 1.5" PIPE. Regardless of live/dead load or double studding. Pretty much kills your trap on the topside. Don't go moving studs too much either.
                              I forget the distance required from a san. tee vent to the trap outlet. 2 times something another. Basically 6" or more.
                              No trap on exterior wall without 6" wall/insulation.
                              Vent within 6'. Drain branch must be increased to 3" within 6' or less.
                              Need primer.
                              I still want to see all of this ran through clear pipe with all the measurements out of range to see if the trap siphons.
