Water Line "Whine"?
  • Water Line "Whine"?
    Water lines near newly installed soft water system are "whining" when a tap is opened. Whine then goes away in a few seconds. System has been in place for about 2mos, whining just started yesterday. Pic of lines below. Regulator?
    Update: I contacted Watts (regulator manufacturer) and their tech support person said this is a "fairly normal" condition where the regulator spring resonates. He suggested I adjust the regulated pressure up/down slightly and this might alleviate this problem. What think ye?
    Re: Water Line "Whine"?
    Nice solder joints.
    Yeah,I guess...That's one possibility...So what happened?
      I think the guy that did the piping needs to buy a level.
        i've been looking for the pink telfon...
          Yea, that be me. The rigid water lines are actually fairly level, better than they look in the pic. The pressure gauge upright is crooked because I originally plumbed the lower line with rigid copper with more slope upward toward the softener valve. But had some leaks. Then I discovered those wonderful water heater lines at HD, ran them parallel for aesthetics (plan to adjust the upright).
          Lowes
          Anyway, I slightly changed the pressure on the regulator and the whine disappeared for now. Should I be worried about a pending regulator failure or is this a relatively normal thing?
            Relatively normal. The regulator has a diaphragm inside which shuts when the pressure reaches a certain point. Many times the diaphragm vibrates a bit while it is partially closed. Try adjusting the pressure up on the regulator and see if that helps.
              70runner,
              nice work.
              it has been my experience for ascetic reasons only, i would line up the gauge branch with the lines of the panelling behind. make them parallel.
              because your working with water and not heating lines you can be crooked to make your work look even better.
              it would be crooked, but it would look straight. you catch my drift?
              just a suggestion.
                I have OCD. I see crooked, I can't sleep....must fix
                  Will a PRV work if installed backwards,or is there a check valve to stop flow !
                  Did You REAM all the copper cuts?
                    No, a PRV will not work backwards. Water will still flow through it, but it will not regulate the pressure.
                      Absolutely
                      For you parallel and perpendicular guys ...I'll be reworking the whole rig anyway (and lining up gauge branch), because there is insufficient room to twist off the regulator (right side) should I need to replace. Going to replace rigid copper to right of regulator with another copper flex.
                      Still no whine from regulator...
                        After looking at your pictures I am not familiar with the regulator you installed. If it is a cartridge style, you can play with the pressure adjustment but I have found that the non cartridge units will sometimes fail if you try to make adjustments in as little as six months after install. Of course incoming water pressure may make a difference so keep this in mind.
                          Not sure about "cartridge" style, but its a Watts N45B-M1
                            It's at Target in the Ladies Hardware isle.
