Gas log valves
  • Gas log valves
    Why are they directional , They have an arrow stamped on their brass body?
    Ports are offset.
    Re: Gas log valves
    I assume you are not talking about a pilot operated control, but just an on/off valve. Depends on what type of valve it is, but many valves have an in and an out, so that when OFF you do not have system pressure against the valve stem packing. Ball valves often don't matter, but other types of valves do.
      Re: Gas log valves
      correct, the packing and the fact that the pressure shoud be flowing up to the washer, not down onto the washer.
        Re: Gas log valves
        Five years from now when it starts leaking gas out the packing washer no-one should be able to find you cause you'll be long gone.
        So don't worry about changing it out.
          Re: Gas log valves
          Don't know why You said that. Valve will go in directional , just curious why some are ,others arn't. This is My home.
            Re: Gas log valves
            ball valves are non directional. 1/4 turn.
            globe valves are directional. inlet is to the washer bottom. outlet is the packing nut side.
              Re: Gas log valves
              Aw JEESH Tool.
              Now here you had to go and make me feel guilty.
              I thought you knew me better than that by now.
                Re: Gas log valves
                No sweat It's not a full port valve. Arrow head brass products
                log lighter valve #258 1/2" fip with chrome flange and Key
