Leak
  • Leak
    Any tips on locating a leaking hot water pipe in a slab? No wet spots yet, but other indicators point to a growing leak. Are there any reliable detectors?
    Re: Leak
    Depending on how bad the leak is I've had pretty good luck using a laser thermometer. You can find hot spots in the concrete with it. Then use a stethoscope to pinpoint a hissing sound.
    Most of the time I look for a way to repipe hot and cold overhead
      Re: Leak
      We had one of our guys do a hydronic heat snowmelt system under a homeowners very expensive italian slate , 4 season, outdoor, olympic sized pool. The stethoscope idea saved his a$$ - he only had to break up a tile or 2 to fix leaks.
        Re: Leak
        TRY THE ABOVE IDEALS IF THEY DON'T WORK
        CALL A LEAK DETECTION COMPANY SUCH AS
        AMERICAN LEAK DETECTION
        THEY SHOULD BE ABLE TO PINPOINT THE EXACT LOCATION OF LEAK
        SAVES BREAKING UP TOO MUCH CONCRETE BEEN THERE DONE THAT MANY TIMES AND THAT IS THE WAY I DO IT
        JERRYMAC
        E-MAILJERRYMAC777@GMAIL.COM
        FIRE SPRINKLER CONTRACTOR,
        SINCE JAN. 1989
          Re: Leak
          Thanks!!!
