Problem with RIDGID SP-500P
  • Problem with RIDGID SP-500P
    Hello,
    I've recently bought the RIDGID SP-500P Pedestal Sump Pump and every time it comes on it vibrates horribly. Has anyone else had this same issue before? It is EXTREMELY loud. The pole that the float is attached to at the bottom is a metal pole and the lever at the top that the pole goes through (to turn on/off) is also metal and it's not a tight fit so every time it comes on you can hear it throughout the entire house!
    How can I fix this?
    Thanks in advance
