clean out
  • clean out
    Directley below the closet flange,but above the 3" main line extension, can I locate My clean out there? Want to come through the rim. Also ,Ishouldn't have to install one here right? thanks Tool. New bath addition
    Re: clean out
    tool, keep in mind that 1 day it will have to be snaked and if it doesn't function properly as a c/o, it's useless.
    can you install it on the 3'' main and not the closet riser. try to enter from a wye, or comby. not a san tee.
    think about from the drain cleaners perspective
    i know you know how to clean drains
      Re: clean out
      I'll run a y and bring it up from there. Thanks for the wisdom as always. Tool
