vent for toilet
  • vent for toilet
    i have a question for all the very knowledgeable plumbers here. i want to move a toilet in an old house (cast iron pipe). i want to know if the vents that are stubbed up in a wall with a termination in the wall. i cant think what they are called will work ok? what size? and i am already sure that they are probably not to code. but will they work ok?
    Re: vent for toilet
    i see plumbers viewing this thread and am sure 1 or 2 of them are knowledgeable enough to answer my post?
      Re: vent for toilet
      Those vents like nice fresh air from a proper roof terminal.
        Re: vent for toilet
        who cares what they like. will they work? i hope i get more people to comment. nohing against you but have never seen you post here. i saw one a high school football coach put in and his commode worked better than min that is vented to nice fresh air .i
          Re: vent for toilet
          Because toilets have internal S traps and are by design a self siphoning fixture, they will operate just fine with no vent at all. In fact the IPC does not care haw far the toilet is from a vent. Those things "in the wall are Autometic air vents?" maybe. If so you have to provide access to them.
            Re: vent for toilet
            NHMaster
            thank you for your post! you confirmed my suspicions and guesses, lol . but really thank you snicerely!
              Re: vent for toilet
              Are you serious?? or are you BS'ing?? I am in an IPC state. A friend of mine asked me about moving her toilet across to the other side of the bathroom, and I told her it would be no problem other than possibly cutting out some sheetrock for the plumber to run a vent to the attic, which scared her off. The house is a ranch, with an unfinished basement, so everything underneath would be easy. Attic access is horrible, however. She wants to move the john so she could have a double vanity instead of the pedestal sink (with studor vent. UGH) she has now. I have a million questions, but I will have to start another thread on this one at some point.
                Re: vent for toilet
                JTRoanoak,
                im no plumber but why not use the vewnt stubbed out in the wall. i know im hardheaded, but seriously as a plumber or foot doctor, i see no difference if you vent it in a wall or 1000 feet above the house. a vent by definition is to let air in right? no house at least my old house is so tight it wont let the toilet flush. am i missing something big? i admit i am a dummy! lol
                  Re: vent for toilet
                  why charge your friend a fortune to ruin her sheetrock, when its not necessar?
                    Re: vent for toilet
                    this can be disputed, the vent can go through the wal cant it??
                      Re: vent for toilet
                      Originally posted by levon View Post
                      JTRoanoak,
                      I'm no plumber either, so I listen to what these people have to say. I do know that a Studor type vent is a mechanical device, and mechanical devices wear out. In this case, when it wears out, you get a funny smell, that is not acceptable! Not to mention, sewer gas isn't the most healthy thing in the world to have leak into your house.An access panel in the wall is not cosmetically desireable in this location. I will run or have someone run roof venting for the vanity, and possibly rework a closet to get a vent in for the toilet if necessary, but I will not seal a device needing periodic replacement into the wall, even if my local plumber recommended it. I would rather not vent the toilet than put a mechanical vent in the wall. When I do side work, I sub out plumbing and electrical, and stick to what I know. I might run some vent lines to the attic to make it easier on the plumber, but if its wet, it's his. I am not a Jackleg, and I use this forum so I can learn enough so that no one does jackleg work for me.
                        Re: vent for toilet
                        I wouldn't ruin the sheetrock, when it was complete you would never know that I was there other than it would be smoother than the rest of the wall!
                          Re: vent for toilet
                          You can't bury AAV's in the wall. They must be accessible for service.
                            Re: vent for toilet
                            JTRoanoak,
                            i'm sure you'll be happy when the drain clogs... think about it again sewer gas use your head
                              Re: vent for toilet
                              There back!! Troll alert ,not even clever
