cast iron baseboard
  • cast iron baseboard
    hi guys, I havent had much expierience with splitting apart ci baseboard and removing the press nipple. I would appreciate any tips or ideas . Im guessing i can use a small chisel to pull apart the sections.
    Re: cast iron baseboard
    Stan: you may need to take this question to the pro's section to get better visibility on it... As a pro I'm curious to learn what this question is concerning
    Okie
      the way i do it is to take the bolt off then put a small piece of wood [ 1x2 ] under the joint and slowly let the other ends go down . if you need to add another 1x2 it may help . then wiggle one end up and down slow until it comes apart .
      then if the bushing is still in one side use pliers to get it out
        thanks for the info
          Remember to always use a new bushing when reassembling sections
            yes i forgot that thanks bill
