grey quest pipe
  • grey quest pipe
    can grey quest coupling connect to cpvc, copper, ect water pipe?
    Re: grey quest pipe
    I will typically convert to PEX using a PB to pex coupling ( A normal PB or PEX coupling should not be used) then change pipe type if I have to...
    Okie
      Re: grey quest pipe
      its quest piping and goes to copper. i just want to know if you can just use a quest coupling to connect the two together?
        Re: grey quest pipe
        I think that the grey quest fittings are good for any OD controlled tubing i.e cpvc, pex, and copper. It should be plainly stated on the packaging though. However a coupling as Okie stated would work and/or you could convert by ust of threaded adapers.
          Re: grey quest pipe
          Hey, why not use a sharkbite fitting?
            Re: grey quest pipe
            you can get a sweat by pb adapter but you can not use a qest coupling to copper
            Mike
            www.plumbinginclarkcounty.com
              Re: grey quest pipe
              any links to what you can use then?
                Re: grey quest pipe
                1. Sweat on a copper to pex adapter and then use a pb to pex crimp coupling.
                2. Use a sharkbite coupling, works on pb, pex, cpvc and copper (do not use inside an enclosed wall).
