CPVC and PVC80 Compatability
  • CPVC and PVC80 Compatability
    Are solvent weld pvc80 pipe & fittings compatable with cpvc?
    Can I join a standard pvc80 fitting to cpvc pipe.
    Are there any advantages to using cpvc pipe rather than standard pvc80 for an industrial process water system?
    Re: CPVC and PVC80 Compatability
    the only way to join PVC and CPVC is via a male/female fitting combination. I would think the only advantage to using CPVC is its temperature rating in an industrial setting. I have seen many cooling systems done in schedule 40 PVC though.
