shower stem removal
  • shower stem removal
    hey there,
    i live in a mobil home and i'm trying to replace the fittings in my bath/shower faucet i was able to remove the hot and cold water valve stems which are brass but i don't know how to remove the shower valve stem can someone please help
    thanks
    Re: shower stem removal
    When you say "shower valve stem", does that mean there is only a single handle to operate your shower?
      i have three handles hot, cold & shower
      thank you so much for responding i have no idea what i am doing and could use the help
      machelle
        The middle handle on the faucet is the diverter for the water to flow from the tub spout to the shower head .
        It really depends on the type of faucet that you have as far as how to remove it. If it is a central brass or a gerber most of the time they screw ito the valve the same as the hot and cold stems do. But I really cant give you a proper answer without seeing the problem.
        If you really cant figure it out I would say that you should call a licensed plumber in your area that you can trust to do the job properly for you.
          Vince
