New Tub Spout
  • New Tub Spout
    Hello all hope someone can help me. I just installed a new tub spout with a built in shower diverter. When just using regular bath everything is fine.But when you use the shower mode water backs up and is running down to the ceiling in my downstairs bathroom. Wich is right under the upstairs one. I have tried 2 tub spouts . Please help thank you
    Re: New Tub Spout
    R U in Reading, Ohio?
    You've got a leak either at the shower lug ell up top where you threaded in the shower arm or down at the shower valve where the shower line connects.
      Re: New Tub Spout
      Sounds like somethings broke.
        Re: New Tub Spout
        I would consider capping off both the shower head and the tub spout and energize the valve. If your rough-in within the wall is leaking you can stop playing with different spouts and fix the leak in the wall.
          Re: New Tub Spout
          Did you caulk around the new spout and was the old one caulked?
          Is the spout a thread on type or a slip on?
          Has it ever leaked in the past with the old spout?
          www.firstresponsedrain.com
            Re: New Tub Spout
            The Old one worked fine it had a little drip leak so the wife asked me to get a new one. It is a push on type. And i havent caulked it yet. The weird part is the bath part works great. It is when i pull up the shower diverter on the spout. The shower does work but when shower in use is when it gets pushed back and leaks downstairs. Almost like a bad overflow washer would react when tub is to full.
              Re: New Tub Spout
              The slip on ones (at least some of them) have a rubber o-ring that seals the spout to the copper coming out the wall. I think you've rolled the o-ring or cut it as you pushed it on, or else yours is just missing, or else you're not pushing it far enough on because it gets a little hard to push when you run up against the o-ring and you didn't want to force it, or your new spouts have the oring groove farther out in the spout than your old one and your copper doesn't stick out far enough to get to it. This will cause water to squirt back into the wall when you put it to shower. I doubt it's in the valve or the shower ell as it didn't do this with the old spout.
                Re: New Tub Spout
                I agree with ace. I do maintenance for a housing corporation and run into the same problem with the slip on diverter spouts. there is no pressure to speak of when running the bath. In our buildings I found the stubs corroded and near impossible to get a seal. I have changed a lot of them so as to use spin on type spouts
                  Re: New Tub Spout
                  Hmmm...yea I woud agree with that,
                  But on a serious note, maybe an un sweated fitting?
                    Re: New Tub Spout
                    I believe Ace called it!
                      Re: New Tub Spout
                      If someone could tell me where l might get this type of push on shower diverter spout. l have one now without the diverter and would like to replace it and add shower head. l live in ontario and have not located one as of yet.
                      Also this style the o-ring can create headaches, maybe lubing it with vasline before you push it on will stop it from ripping or rolling
                      Thanks
