Filling a sealed system
  • Filling a sealed system
    Cant seem to find the filling loop!! Its not near the boiler or cylinder any other way to fill it up
    Re: Filling a sealed system
    Can you provide more details?
    Oil, Steam, Gas, etc ......Picture works as well,
    There is a feed somewhere I am sure
    BTW - Love the SCREEN name
      Its a gas boiler... I was bleeding a few rads and the pressure has gone under 1 bar... the rads upstairs have plenty heat but ground floor is pretty poor
        Should be a make up line with a regulator somewhere near the boiler.
          coming off the boiler theres a lever arm, joining up two pipes, could i fill from there if i disconnect it
            Not sure what you mean by lever arm. Pictures would really help.
              I think he's talking about the fill valve.
              Proud To Be Union!!
                union that fill vavle, when i turn that valve on when the heating is off it does nothing... but when the heating is on and i turn the valve on it makes a noise but i turn it off quick, if i turn the valve on could it drop the pressure in the gauge or fill up the pressure
