Why does the toilet flush every other time?
  • Why does the toilet flush every other time?
    I have a toilet that will drain fully (and refill) on one flush and then just swirl about but not drain (or overfill) on the next flush. It does this same thing every other time. A plumber had looked at the equipment in the tank and said it's working fine, but they could not suggest why it might be doing the draining thing. They said that it wouldn't do what it's doing if the equipment in the tank was faulty or if there was a clog in the lines. It's been doing the same things for the 4.5 yrs we've been in the house. Any ideas?
    Re: Why does the toilet flush every other time?
    Sounds like a clog to me, I have seen an instance like this when there was a matchbox car stuck in the lead bend.
    I bet if someone pulls that toilet and snakes the Water closet and also the bend you will find something.
    I am willing to bet money on that
      Could be jet holes plugged in the bowl.
        Does not sound like a clog to me. Years ago when Fluidmaster fill valves first started to hit the market many of us discovered that they put so little water through the refill tube that on many toilets, particularly the 3.5 American standard models that there was insufficient water in the bowl to generate a good flush. The big complaint was the same complaint that you are bringing up. So take a look at the water in the bowl (not the tank) and see if there is a height differential between the good and bad flushes. A good test will be to put a little water slowly in the bowl after the toilet has flushed well and flush it again. If this turns out to be the problem then you may have to consider a different fill valve. The new age Fluidmaster fill valves work great.
        • jackb
          jackb commented
          Editing a comment
          The Alternating Flush Phenomenon Explained
          I believe I have solved this actual problem with my toilet, and RP's mention of the low refill amount is essentially the answer. In my case the low refill was intentional, caused by the modern type of tank valve that includes a little throttle valve on the refill tube itself. Notice the green lever in this photo:
          https://images.homedepot-static.com/...0x-64_1000.jpg
          The purpose throttling the refill tube is to save water, by making sure that the bowl [not the tank] only refills to it max and stops, without any water unnecessarily sloshing over the s-trap and down the drain. A few weeks ago, I thought my tank might be overfilling a bit so I arbitrarily backed off the green valve a smidgeon. Oops. It wasn’t until weeks later that we noticed it was flushing poorly. It’s a mudroom bathroom so it doesn’t get, um, “intensive” use. By that time, my little ad hoc adjustment was a long-lost memory. Hell, I barely remember what question I’m trying to answer here.
          Anyway, my wife noticed the every-other-flush pattern. (Brilliant!) I get on the web and find mentions of:
          - Clogs (of course)
          - Mismatched flapper to tank size
          - Clogged vent holes
          - Bowl water level
          - Vent stack clogged
          All seem reasonable as causes of slow flushing, but the bowl water level seems to be the key to alternate flush/no-flush. Here’s how it causes poor flushes only on alternate flushes. When the toilet flushes successfully, suction/siphon action draws the bowl level BELOW the full level; ‘full’ would mean level with the top of the S-trap). If the refill tube isn’t doing it’s full job, the bowl gets underfilled. Now you flush it and it doesn’t flush strongly because not enough water starts through the S-trap to create strong enough siphon action to draw the whole mess along on its merry way. BUT, BUT, BUT… because it flushed poorly, the bowl is now full (!) and you get a good flush the following time. Lather, rinse, repeat!
          So, any problem which causes the bowl to underfill can logically result in the alternating good/bad behavior. I’m not a plumber, but someone who is could tell us which problems, in addition to the under-performing refill tube, could result in not filling the bowl. And any of those would be potential root causes.
        Thanks to both of you. My father-and-law suggested that I take a damp cloth and wipe down the holes to see if I get any residue that might suggest rust or sediment clogging the holes. Came up clean and water does seem to flow freely from all of the holes surrounding the bowl (though I don't know how fast the water should be flowing to say if it's working right).
        I will say, having tested it a moment ago, that the toilet does seem to make a strange suction or gurgling noise from the discharge in the bottom of the bowl (like if you breathe in hard through your mouth with your tongue at the roof of your mouth). Would this continue to suggest in your mind that there might be something stuck down in the line that's causing the flushing situation/noise?
          Still leads to the toilet in my opinion based on the information provided. Replace fillvalve, clean holes with clothes hanger, don't work-Make a new friend in a plumber.
          Good luck.
            could be a 1.6 gallon flapper installed in a 3.5 tank
              "It's been doing the same things for the 4.5 yrs we've been in the house."
              guys,
              wouldn't this suggest a venting issue?
              Vince
                guys,
                Vince
                Or just proves pure lazyness ....j/k......I would have fixed it at 3 years
                  guys, you all are over thinking this
                  toilet flushes on a #1
                  and doesn't on a #2
                  then back to a #1
                  eat more fiber
                    and doesn't on a #2
                    then back to a #1
                    eat more fiber
                    LOL....Right exactly
                      I've seen this before! One arm is longer than the other!
                        could the hard water deposits in the toilet and drain cause this?
                        I have met a lot of stupid professionals.
                        I have met a few smart DIYs
                        I'd rather be a DIY, as I have already proven to outsmart and outperform most so called professionals.
                          Why wont anyone pull the toilet>?
                          Am I missing something here?
                            and doesn't on a #2
                            then back to a #1
                            eat more fiber
                            Yeah......either that, or the toilet's possessed and is fighting back......
                            "Yeeesh, you again? All right.....I'll fix you.......half-hearted flush coming up..."
                            Wait a minute......forget about the movies "Cars" and "Monsters, Inc.", how 'bout "TOILETS"?
                            Toilet Seat - "Jimmy, I'm afraid it's my last day.....I heard them talkin - I'm wigglin' too much and I'm too cold in the morning. I hear they're gettin' on 'a them toilet seat bidets. Seeya, friend, but I'll say hi to Frankie the tankless water heater at the dump..."
                            Bowl - "No Sammy.....say it ain't so.....I'll flush harder next time, it's just that my flapper ain't as strong as it used be.......maybe I'm next..."
                            Sink - "We're all doomed - here comes the damn dog....."
                            Camera angle turn - zoom in to slobbery bulldog coming towards toilet looking thirsty...........
                            I can't wait to see the Happy Meal toys..........
                            I'm on "The List" and I love it!!
