winterizing a heating system
  • winterizing a heating system
    I have a customer who uses a wood stove to heat his home he hardly ever uses his boiler he has hot water base board heat what is the best way to plumb his boiler to add antifreeze to his system.
    Re: winterizing a heating system
    I usually pump the antifreeze (cyro-teck please, 50-50 mix) in through the boiler drain and purge wter from the purge and balance valve.
