Tekmar 256 installation
    Re: Tekmar 256 installation
    Glad you got if figured out
    You'll still need to tweak the Tekmar control to suit your comfort level and outdoor temps.
    Tomorrows lesson: 'How To Properly Extinguish an Electrical Fire'
      Dont say that thats what im worried about.
      I drew my own sechematics and i will try to post it later on in the day. If you would be so kind as to look at it and tell me what you think.
      Thanks, Jeff
      Slant fin S-120-DP boiler
      L8148E aquastat
      3 V8043E zone valves
      Tekmar 256 Boiler control
        Ok here are some pics.
        L8148E aquastat
          Who's idea was it to add the jumper from L2 to #3 on the R845A?
            Me. How else would you get the HOT to get to the pump? Otherwise 3 and 4 are just connected to each other with the relay. Thes nothing there 120 or 24 volts without adding it somehow Also the wiring that i drew is off. The black actually goes to the L1 which says HOT on teh shcematics from honeywell and the white goes to the L2. dunno why they dont go in order 1,2,3,4,5,6, accross the bottom.
            L8148E aquastat
              Excellent job, Jeff
              No where in the wiring schematics do they show that jumper but you managed to figure it out. See?, you knew what you were doing all along
                You had me scared there for a second. Well i have alot of knowledge in automotive electrical and i dabble a little in home wiring so i know how circuits should work. But this one had me stumped. I think its all that A/C current stuff. Im set to think on D/C so it took me a few tries. But i knew the 3 and 4 werent fed by anything. (i used a volt meter to be sure) so i figured the jumper had to be done.
                But thats correct?
                L8148E aquastat
                • #23
                  bill im so proud of you
                  it is nice to help other people
                  good job jeff not bad for a automotive technician
                  • #24
                    Either way thank you both.
                    Have a great Holiday guys
                    L8148E aquastat
