Low pressure supply water line change
  • Low pressure supply water line change
    1/2" copper supply line in over 60 years house had been changed to 3/4" copper pipe by city, but city changed only around curb stop which is located 60ft away from the water meter.
    Now I have realized the water pressure is better than before but it is not enough the peak demend time.
    The meter's inlet and outlet is 3/4" but used reducer to 1/2.
    So, I am thinking to change the 1/2" supply to 3/4 from the outlet of the meter to the first tee fitting (just before cold water supply line and hot water tank).
    If I do that it will be 3/4" supply then 1/2"(60ft) from curb box or near to meter and 3/4" from the meter to first tee fitting.
    They have
    1 bath tub
    2 toilet
    2 lavatory sink
    1 kitchen
    1 washing m/c
    1 laundry tray
    1 garden hose bib
    I will be about 17 fixture unit.
    If the water pressure is ok then they will make a shower booth.
    Do you think the water pressure will be better if the line after meter is changed to 3/4?
    I
    Please give me some advice.
    Thank you.
    Re: Low pressure supply water line change
    What do you mean by a shower booth?
      I mean they have only one bath tub and try to build a shower or another bathroom in basement but there water pressure is low.
        Gotcha.
        What is the pressure?
        Is there a PRV?
        Any galvy distribution?
        2 stories?
        The quick answer is that it "should" be ok with 3/4" supply from the meter to inside the house but you have to factor in everything.
          Not sure but less than 16L/min (which is our city is minimum)
          Is there a PRV?
          None
          No
          2 stories?
          Yes.
          What kind of other factors?
          Thank you.
            16L/min is Volume-right? What's the actual PSI?
            Plus, you have a minimum of 16L/min minimum for a 3/4" meter. You have an immediate restriction so that number is gone. Removing the restriction will give you 4.22 gallons/min. which is pretty low here if I understand this right. That's less than 2 showerheads.
              I have not checked but pretty sure it is less than 40 psi.
                No wonder they're having some problems.
                A maximum of 4.22 gpm at 40 psi plus friction loss and a second story= problems.
                  Toronto's minimum water pressure is 276kPa which is about 40psi.
                    Is it?
                    Hum... I asked their neighbor and they are satisfied their water pressure.
                    Can a old meter restrict water pressure?
                    Their water line is 1/2" soft copper tube.
                      Is there any water mimimum pressure in your place?
                        What satisfies a person is subjective. I'm going off the numbers you are providing.
                        Run the 3/4" line. If they aren't satisfied then they'll have to explore other options such as paying for a commercial meter or a booster pump system.
                          Thank you good night.
                            The City of Toronto will let you run whatever size copper line to your house that you want. I ran a 1 inch copper "K" type line to the property line (which I paid and installed) at which point the city ran a new 1" copper line from the street main and joined it to mine with a Mueller valve (which they paid for). The basement is all 1 inch then goes to 3/4 inch and 1/2 inch upstairs to the 3rd storey. NO PROBLEMS FOR WATER NOW!!!
