shower valve
  • shower valve
    I have removed a 4' fiberglass shower and replacing it with a tile shower. I have replaced the old valve with new delta valve. I am not certain of the mounting height. The valve screws to a block in the wall how deep should this be? I have 1/2 backer board and 3/8 tile.
    Re: shower valve
    I dont instal many delta faucets but most rough valves will have a tile flange on it that you should mount flush with where the finished wall will be after tiled . like I said I am not sure if delta faucets come with the tile flange but I know that moen faucets do.
      Re: shower valve
      Put the trim on the valve and check for yourself
