trap primers
  • trap primers
    are there any types of trap primers that use full pressure as opposed to a pressure drop
    Re: trap primers
    When I was in new construction it seemed that all the jobs were spec'd for them but never installed, connected.
    It seemed like the reason mostly followed the erratic problems with the devices, keeping them to work without failure.
    I believe some of the best trap primers were designed years ago that consisted of the toilet flush ells that had a small tube that sent water to the drain by one's flushing the fixture, same as the old style laundry tub faucets with the drain for floor drains.
      Re: trap primers
      We use them all the time in S.F. They work fine.
        Re: trap primers
        What brand name are you using tool, Watts?
          Re: trap primers
          Yes, Watts
            Re: trap primers
            I have yet to find a trap primer that works the way it should. I think they are a waste of money and time, unless installed with a commercial flush valve toilets with vacuum breakers, as Dunbar mentioned.
            We have to use them in residential floor drains.
              Re: trap primers
              I do not know of any.Most,as you have posted,require a pressure drop.You have to have a pressure drop that can be sensed be the primer.Years ago I had to tear off a wall and relocate one from a drinking fountain(per Architect) and relocate to a higher volume dropping fixture.There is a plumbing contractor I've been helping out that keeps putting them in the middle of the system or running these crazy length branches off the main.I keep warning him....
                Re: trap primers
                We had problems with them so I started to precede them with a ball valves. The inspectors did not like this and told us to get rid of the ball valves. I also did the same thing with expansion tanks and got the same response. I'm big into shut off valves and anytime I think it would help out a future situation I install one. The plumbing code does not agree with me.
                  Re: trap primers
                  I do the same with exp. tanks, but i remove the handle so it can't be shut off easily
                  West Trail Mechanical Ltd
                  www.westtrailmechanical.ca
                    Re: trap primers
                    in michigan we have to have a valve in front of the trap primer, our inspectors consider it a fixture
