vent fixture units
  • vent fixture units
    How many fixture units are allowed on a 1-1/2 vent?
    Re: vent fixture units
    Eight fixture units but no six unit traps or water closets.
      No water closets?
        IPC will let you vent a sater closet.
          What's a sater closet?
            No water closets?
            Mark, you can't vent a water closet under UPC with 1.5"?
              No not under the UPC. There is a 2" minimum for water closets.
                The books in the truck but if I recall under IPC you can vent a bathroom group with a 1.25" vent.
                !##$$!#Q! DIFFFERENT CODES FOR THE EXACT SAME THING!
                  I believe a bathroom group is 5 dfu and an 1.25" is only good for 2 dfu under the IPC.
                    I think it is 1.5" for a bathroom group JC... ( 1/2 the Diam. of the 3" line for closet)
                    My book is in the truck as well...lol
                    Okie
                      Thanks guys. I distinctly remember this as a "trick" question on the test years ago. Obviously noone uses 1.25" vents but for some reason I recall there was an exception for this one situation.
                      I still get confused venting. You can use ABC size if wet venting but you must dump into a stack with X distance when only Y amount of DFU's are present. If you increase or decrease any of these then none of this applies. DUhhhhh......
                        under ipc I don't recall exactly how many dfu's can be done on a dry 1.5 vent, but I seem to recall a wet 1.5 only being able to vent 1 dfu. Which I interpreted to mean if a lav is venting anything but itself, you need to bump it to a 2 inch vent. But, my book is in the truck at our shop.
                          Under the IPC an 1.5" wet vent is limited to 1 dfu. As for an 1.5" standard vent it varies depending on the drain size and developed length of the vent.
                            Here are a couple taken straight from the IPC 2006...
                            916.1 Size and developed length of stack vent and vent stack
                            1 1/4" vents 2 DFU no more then 30'
                            1.5" vents 8-10 DFU 30-150' ( to lazy to write whole table...lol)
                            908.3 Common vent size
                            1.5" = 1 DFU
                            2"= 4 DFU
                            2.5 and 3" = 6 DFU
                            909.3 Wet Vent
                            1.5" = 1 DFU
                            2"= 4 DFU
                            2.5"=6 DFU
                            3"= 12 DFU
                            910.4 Waste stack Vent Size
                            1.5"=1 DFU into one branch or 2 DFU Total discharge for stack
                            2" = 2 DFU / 4DFU
                            I was sure you could vent a bathroom group with a single 1.5" line ( not that I would) hmmmm I will keep looking
                            Okie
                              10
