How to clean solder from copper pipe?
  • How to clean solder from copper pipe?
    What's the best way to clean off old solder from a copper pipe. I'm trying to resolder a valve and don't have enough pipe to cut off to where it is clean.
    thx
    Oscar
    Re: How to clean solder from copper pipe?
    With the pipe empty, heat it up hot enough to where the solder will drip off, wipe off with a rag.
      then re sand it and put flux on it
        Thanks guys.
        It's on and with no leaks.
        And no, I'm not going to start a thread called "I want to become a plumber".
        http://www.ridgidforum.com/forum/showthread.php?t=22060
        Oscar
          You can be a plumber if you want. Now if you would've started off the thread figuring out how to install the new Sharkbite ball valve, I think the guys would've banned you from doing any future plumbing.
            Or what flat rate vice T&M should be ! ! !
