PRV: replace or repair?
  • PRV: replace or repair?
    In my haste to get my soft water system installed, I plumbed the PRV a little too close to the garage wall. Its a Watts 45BU model with NPT female inlet & NPT threaded union outlet.
    I need to replace the valve but of course there is not enough room to rotate the valve off the copper male inlet, unless I cut a relief into the wall paneling and drywall (which I'd rather avoid). 2 options that I see:
    1. Repair the PRV with valve repair kit.
    2. Hacksaw the PRV near the female inlet, install a double union PRV.
    What think ye experts?
    Re: PRV: replace or repair?
    Replace with new, done deal. Double union allows for easy replacement down the road.
    I've never rebuilt a PRV, and I don't think I'd warrant it because of fear of leaks.
    Something about a factory seal makes my insurance feel good at night.
      prv's are disposable items---like all watts backflows -- they are meant to be tossed out----if you cut it off, be careful--you cut the threads, you make a lot more work
      good luck
        I'm with Dunbar for this one, way easier to put two unions in
        if u cant bedazzle em with briliance, baffle em with bulls&*t
