Pop Up Lavatory
  • Pop Up Lavatory
    I'm replacing the pop up lavatory in my bathroom sink and the standard 8 inch size that's commonly available is too small. It looks like I need a part that has extra long threading for thick counters, but I haven't been able to find any. Is there another solution that could work or is there a website that would stock replacement parts for what I need or even a store that would carry this in the Cincinnati area? Thanks.
    Re: Pop Up Lavatory
    EDITED: Are you replacing the pop up assembly or the whole faucet???
      Re: Pop Up Lavatory
      I am replacing just the pop up assembly.
        Re: Pop Up Lavatory
        You need to post a pic in my opinion.
        Most popup assemblies have enough adjustment for the majority of situations. There's often another connecting rod with adjustments that connects to the pop up rod that you see/use on top.
        And "extra long threading for thick counters" does not make sense when talking about a pop up assembly.
        Pics would help.
          Re: Pop Up Lavatory
          J.C., thanks for taking the time to respond to my posts, but luckily yesterday I was able to find the correct piece that I needed after searching many stores.
