How to Install an Emergency Eyewash Station?
  • How to Install an Emergency Eyewash Station?
    How do you install emergency eyewash station?
    My company alway fixes any direct connected eyewash station with p-trap to indirect connection without p-trap but I can't not find any code for that.
    It should be protected by backflow but I am doubting that has to be indirected.
    How do you install eyewash station in your place?
    Re: How to Install an Emergency Eyewash Station?
    Why would it have to be either?
      My master orders to fix it.
      General contractors install direct connection to sanitary drain with P-trap.
      and my boss does not like it so I alway repipe with indirect line.
      Indirect connection is better and safer but I am not sure it really has to be indirected.
      manual only recommend to use a backwater valve.
        Gotcha'. I think. I've always seen them direct connected & NO backflow. Don't have the IPC codebook here right now but why would there need to be a backflow?
        Are there RPZ's on water fountains?
          I cannot find anything in Ontario code nor IPC(international plumbing code).
          I have seen many places installed indirected connection and when I see it need to repipe it.
          Anyways people concern about backflow.
            I don't believe emergency eyewash stations even require a drain
              Agree. It's emergency use only so what is more important, personal safety or a little water on the floor from an eyewash or shower? If you had a floor drain w/trap then you'd have to deal with it going dry since it is such a low frequency use.
                Because they are an emergency use fixture only they do not need a drain. You can let it dump on the floor or stick a 5 gallon pail under it. If you want to pipe it to the sewer it needs a trap and a vent.
                  i installed a water eyewash station years back that simply drained on the floor.
                  i see there are self-contained units on the market that use a saline solution instead of water.
                  this might be another option for you customer.
                  http://www.fast-rescue.com/proddetail.php?prod=EWS3000
                  Vince
                  just a thought; if you are the only one there and you get both eyes splashed, how do you find the eyewash station?
                    I don't think they do either. I could be wrong
                      I aksed with my boss today about it which I cannot find any clue.
                      He sad when he installed eyewash station a inspector told him to do indirect connection.
                      When I install in maintanance room which has mop sink I pipe the eyewash station drain into mop sink indirectly.
                        i installed a few of them in a prison warehouse. and a bunch of them in aclean room for making disc's...all of them were just 90 down to a floor drain
                        and the water was direct hookup.1 1/4.. pull the chain wet eveerything
                        khlee815. i had a plumbing inspecter state that he would accept drilling a 1/2" hole into the side of a mop sink basin as the airgap , because the 90 turned down into the sink,leaving no gap persay
                        how cool is that??
                        I like it like that !
                        and, It's like that now!!!!!!!!!!!!
                          I had to repipe the direct connected drain line with p-trap to indirect drain into mop sink with out air break.
                          I know it is against our code but if I make proper air break (1 pipe diameter or lager in here) the next day I have to go back to the customer again because they don't like spash water around floor.
                            I cant say about codes other than in Ohio but in our code book a waste connection is not required for an emergency eyewash station.
                            If you choose to run a drain line it should be an indirect connection by an air gap into a floor drain by an air gap. If the total developed length of the indirect waste is over 4 foot it would have to be trapped.
                              Thanks!
                              I always wonder if any trap need for indirect conntion.
                              Our code does not mention about it and some install trap and some don't.
                              I am the one who don't install any trap wit indirect connection.
                              But why 4' any reason?
