Honeywell or Watts?
  • Honeywell or Watts?
    I am in need of a Thermostatic Mixing Valve and was wondering which is a better valve Honeywell or Watts?
    Re: Honeywell or Watts?
    Follow -up question.
    What is the difference between a Tempering Valve and a Thermostatic Mixing Valve ?
      What's the application?
        I am going to install a domestic hot water coil in a solid fuel furnace. I will use the tempering valve at my hot water tank to regulate the water temp.
          Use Cash Acme www.cashacme.com
