Toilet Auger
  • Toilet Auger
    We have older family members in our house and our toilet is always stopping up. There are no toys (no little kids) and we are trying to figure out if we have what we need. We purchased the RIGID 6' Heavy Duty Toilet Auger and it is still not going down. Are we doing something wrong? It is better, but not great. Can this product be added on to make it longer? Or are we just doing it wrong? Any help you could give us would be greatly appreciated.
    Re: Toilet Auger
    What does "it is better but not great" mean exactly?
    How old is the toilet?
    How old is the house?
    Septic or city sewer?
      Re: Toilet Auger
      If the blockage is occurring in the commode you shouldn't need the 6 ft extension.
      When working the auger you may need to spin it in both directions left or right hand rotation until it extends all the way through.
      Don't force it in, let it work it's way through with slight downward pressure.
      You may have an object in the commode.
      Most people blame the kids, but in my experience it's usually the adults that are to blame.
      Forks, spoons, knives, underwear, toothbrushes, plastic caps, coke cans, cell phones, you name it.
      Older folks sometimes take medications that make their stool hard which causes alot of problems.
        Re: Toilet Auger
        If there is an object in the commode you may need to remove the commode, turn it upside down, and see if you can see an object in it.
        After I auger commodes and the water goes down, I always flush 5 times with toilet paper.
        If it flushes 5 times with toilet paper, it was probably just a toilet paper and stool blockage.
        If it stops up again, I pull it and check for objects.
        Are you sure it's not further down passed the commode in the sewer line?
        Run water in the lavatory and tub for 5 minutes to check. If the commode bubbles from running water elsewhere the sewer is stopped up.
          Re: Toilet Auger
          One of the stranger ones I had.
          We couldn't get things working right so I decided to remove the toilet, take it outside and check everything.
          As we were taking it out, you could here something in it "shing, shing" back & forth. When I got it dismantled and worked it around we got about 20 coins out of it.
          The kids though it was some kind of Wishing Well.
            Re: Toilet Auger
            Forcing the auger in may cause it to flip in the commode and get stuck!
            Careful just letting you know.
              Re: Toilet Auger
              It was in a way, your wish of easy money came true!
                Re: Toilet Auger
                Maybe all plumbers should start throwing pennies in commercial toilets.
                Best return on investment currently.
                  Re: Toilet Auger
                  One time at a Burger King, I pulled a commode, flipped upside down, couldn't see anything. Tried augering from the bottom, no luck.
                  Boss told me to bring it outside, he was coming.
                  So there we were in the grassy area of Burger King with an upside down toilet. People in the drive-thru staring at us.
                  He brings some lighter fluid. We set the commode in a position to hold the lighter fluid in the ptrap. Lit it on fire for two minutes. Put the fire out. Let the commode air cool. Ran auger and pulled out a childs action figure. The fire burned the arms and legs which caused them to shrink, and came out easy.
                  Learned alot from that boss, but he was a D-bag.
                  Haven't tried it since, I just sell a new commode now.
                  We were lucky that the commode didn't crack under the heat.
                  Ms. housewife, This is not a recommendation. What we did was dangerous and stupid in hindsight.
                    Re: Toilet Auger
                    Well, how's it going? Update please.
                      Re: Toilet Auger
                      Is the comode a new one ? Or a good old one??
                        Re: Toilet Auger
                        Had a 2 year old son and a missing door knob. The toilet flushed fine 4 times out of 5? I used a plunger and could here a slight rattling sound. Took it of, turned it upside down and the doorknob fell out.
                        I asked my son if he threw it in, YES he said, with a big smile on his face.
                        And so it goes!
                        Buck
                          Re: Toilet Auger
                          Before I learned my lesson I fought trying to unclog drain with a Ridgid auger. How many hours I don't even like to think about. The auger kept going into a vent pipe and I coudn't get it to remain in the main line. Finally I called a drain man who worked just a few minutes and unclogged the line. I have never tried to unclog a line since - always call the drain guy.
                          Could this be happening to this lady - the auger going into a vent and not staying in the line?
                          Tom
                            Re: Toilet Auger
                            my ex knocked a compact mirror into the toilet, and either didn't notice, or didn't mention it. I fought with that toilet off and on for a month, it'd flush fine every time i'd plung it.
                            finally bought myself a comfort height toilet, yanked the old one, looked into the bottom, and was staring myself in the eye. stupid mirror.
                            The plunging would stand it up, and flushing anything would lay it down.
                            The scary thing is that it actually let things flush.
                              Re: Toilet Auger
                              Tom
                              I got the impression she was talking about a toilet auger which is used to remove blockages from inside the commode itself as opposed to a cable machine that would be run through the pipe as I think happened in your case. If this is true she would not have to be concerned with the vent.
