Back flow preventers
  • Back flow preventers
    How do you know when your going to need an expansion tank when you put in a back flow preventer, just wait and see if the relief valve opens on the HW tank? Any other additional equipment installed with RP's or DCVA's?
    Re: Back flow preventers
    By code you always need an expansion tank when a BFP is installed.
      when there is a check valve on the system or backflow preventer. also if the incoming pressure prior to the regulator is at a pressure equal or greater than the relief valve setting. (150psi).
      most modern regulators have a thermal expansion bypass.
      an easy way to test is to install a hose bibb pressure gauge on the water heater and watch the gauge when the heater is heating with no other use in the house. the pressure will go up and should equalize to the street pressure.
      if you have any form of backflow preventer/ check valve, the pressure will surge beyond the street pressure. keep in mind that the longer the heater runs, the higher rate of expansion, especially with winter cold water.
      if in doubt, install the tank. air charge it to the current regulated pressure or slightly less by a couple pounds.
      p.s. welcome to the ridgid forum
        to the Forum.
        It really depends on what Code you are working under. If you are working under the IPC see post number 2. If you are working under the UPC see post number 3.
          if you want a simple answer, see post #4
          good morning mark
            thanks for the response. I have few of these BFP's to install in some of the municipal buildings ( arenas, fire halls, public pools, etc).Some of the buildings have a 2" water service that reduces down right at the water meter to 1". For those I was thinking I'd put a 1 1/2" BFP and water meter on then reduce down to 1" so I would'nt lose to much pressure. Make sense to anybody?
              Unfortunately that's not true for us in Canada. Not a code requirement.
              West Trail Mechanical Ltd
              www.westtrailmechanical.ca
                Doug I'm assuming you're in Ontario?
                  Yes, indeed. I took the BFP course and I believe the municipality decides on the code parameters.
