Water Heater making noises
  • Water Heater making noises
    My water heater is making noises like water boiling or bubbling. Other than the noises the water heater works perfect. What could be the possible cause?
    Thanks,
    Jim
    Re: Water Heater making noises
    Some questions-
    1. Well or city water?
    2. How hot is your water coming out of the heater?
    3. Gas or electic heater?
      jim, typically on a gas heater, sediment has built up on the bottom of the tank.
      it's usually too late to flush it out as a homeowner.
      how old is it and do you flush it out on a yearly basis?
      the boiling is water droplets getting superheated between the hot steel tank and sediment. when you open a faucet and the pressure drops, you will get a louder rumbling noise as water boils at 212 with no pressure and higher at higher pressures.
        Thanks for the replys, the water is well water with a gas water heater.
        Jim
          This is the answer to your question
            The guys are right and run her till she blows............................
              It's the heat traps! I see it all the time or hear it i mean
              You can lose with me, but you can't win without me!.... PPI
                Do you own any chickens?
                  I do why?
                    Had an electric that was Very Noisy (Lots of minerals )
                    AO Smith sent out sand Hogs solved the problem ...
                    I now tell all my customers "Noise" Is Not covered by warrenty !
                    Dave
