Water heater flexes
  • #31
    Re: Water heater flexes
    Why would a licensed plumber that knows how to solder install flex connectors that many have stated are inferior to hard piping?
    • #32
      It is required in some places. See rick's post.
      • #33
        Other than California or Arizona requirements?
        • #34
          As long as there's no earthquakes in my area, I'll never use them.
          • #35
            i'd never heard the term before I moved here, we also always called it strapping. of course, we also used plastic strapping.
            • #36
              Another common name is Banding Iron. Probably the more common in my area for galvanized strapping. That plastic crap is just strapping. Personally, i prefer the banding iron with stove bolts over the plastic. In new apps its easier to adjust for fall, but prob takes a little longer and cost more.
              Tip for plastic strapping that you may already know - heat up a 16d nail and lay it on roll of strapping in a couple of places melting the plastic slightly. It will keep from making a knotted up mess out of roll and allows you to unroll stap easy enough.
              • #37
                I used to just stick tape to the side of the roll, though thats an awesome tip. around here they use a lot of J hooks to support pipe, seems pricey to me but they though I was nuts for strapping everything.
                • #38
                  I Thought the Insurance Company Was Nuts for requiring Straps on a heater in Florida ... That Was a First ! ...
                  Dave
                  • #39
                    On occasion ,I make My own braces. Use either 1/2" or 3/4" elec. conduit. Hammer each
                    end flat for 2- 1/2". drill hole and bolt. On a remodel we're doing now walkout garage basement S.F. 24' x 50' concrete, some dirt, and old cast Iron removed. New C.I. 4 " gravel 2" sand visquine 4 "concrete with 1/2'rebar 18"E.W.. plywood with 2x4 frame suspended from 2x10 joist above with 1/2" elec. conduit.
                    These carry the water heater,washer dryer stacked . We can pour concrete under these folks still have some comfort.
                    • #40
                      Flexes are the flexible pipes that supply water to the Hot water heater. Not the strapping. Brasscraft makes some if you would like to see them go to...
                      http://www.brasscraft.com/Products.aspx?Id=227
                      • #41
                        seperate conversation going on in the thread, someone was asking what pipe tape was
                        • #42
                          If on occasion somebody buys some wholly iron, I always loose it. It's the weirdest thing.
                          • #43
                            Tool can you get a picture of that?I can't see it yet.
                            OK now I see it...Temporary lift
                            • #44
                              I've seen this done a bunch for sway braces as well. However, it is not legal to use for earthquake as they are not listed.
                              • #45
                                Thank's Mark, on each platform the rear is supported By the wall, The front by the conduit.
                                This is temporary until slab poured and tile laid. On underslab C.I. inspection , I may get spanked ! WILL TAKE PICTURES AND POST. Thank's fot the heads up
