Bad pipe threads
  • Bad pipe threads
    what do you think is causing this to happen
    the cutters are new
    the pipe was cut straight
    Re: Bad pipe threads
    A little too aggresive with the reamer ?
    Steve in the trade since 73 doing new residential/Commercial work
      Were the cutters put in the die in their numbered order? Are you using cutting oil and not some other kind? Also the foreign pipe these days can have hard and soft spots causing galled threads. Try a different piece of pipe for giggles.
        Did you ream after threading?
          The threads look good but not great. What pipe cutters are you using and are you torquing them down too much?
            I'm wondering about the order.
            The flat tops on the ridge of the thread.
            Sometimes when the dies need to be tightened up I'll see something similiar.I've never seen an end like that though.
              I don't see much of a taper.Or maybe it's me.
                Maybe the cutting teeth are out of order in the diehead
                I don't see much of a taper either
                  im using oil dies are in the right order and i think it is foreign pipe
                  nope
                  before
                  a Ridgid 32895
                  i do check this every so often
                  there is a taper just cant see it in the picture
                  this does not happen this bad all the time but the first thread starts off rough a lot
                  thanks for all the ideas
                    how many turns of the fitting by hand before it gets tight?
                    Vince
                    if i recall correctly, about 2 full turns by hand.
                      I was threading 1.5" black iron this week, started with a Reed die, tore out some threads, so I switched the my ridgid die. It was even worse, turns out the teeth were pretty worn out, so I bought a new set. It was identical to the reed die with these new teeth. my conclusion was imported, low quality pipe. I can't think of what else might have done it.
                        It says USA on his pipe, or is that writing part of the pipe "spec"?
                          I have had to use motor oil before in a pinch, and rough, jagged threads were the result. Good, clean cutting oil (like Hercules or Ridgid) makes a big difference. Fittings should thread on 2-1/2 to 3 turns by hand.
                            USA, a city in Japan. (no kidding)
                              Vince is just for the pic
                              that pipe says USA
                              Was it all your pipe or just the 1 1/2" ?
