Calculating the bending angle of a plate in a pipe.
    Re: Calculating the bending angle of a plate in a pipe.
    Silence on his end......I'm guessing a STILL ! I want invited over to approve the final product.
      IF HE IS CLOSE TO A TRAILER PARK, IT COULD BE A NEW SPIN ON A NAZI METH LAB...
        i do not have a clue at what your making . do you plan to solder the plates together if so will you call me i want to watch. they do make 3inch copper pipe
          A circle doesn't have an angle...a circle is a circle and an angle is an angle... the only way I can see a circle having an angle is relative to something else in a third dimension. You've got to communicate what you are asking more clearly if we are to understand.
          Agree; sleeving pvc with some kind of formed copper sheeting sounds like a poor plan; time consuming and prone to failure. Better would be to just use pipe appropriate to your process.
