The SSP-1000
  • The SSP-1000
    I am having trouble with my SSP-1000 submersible sump pump. It turns on constantly even when the water level is too low to pump water. I cleaned off the electronic switch and the pump case and it fixed it for a short time. i was wondering if other people have had or heard about similar problems, and if so any possible fixes.
    Re: The SSP-1000
    I have the same issue. I just sent out a request for help...hopefully we get a reply
      Re: The SSP-1000
      Get a float switch for the pump. If you call Ridgid and tell them of your issues they will most likely send you one. The electronic sensor switches can be problematic.
