Hot Water recirculating crossover
  • Hot Water recirculating crossover
    I have a recirculating pump on my hot water heater. Recently I have started experiancing hot water out of my cold water sides of faucetts.
    Can anyone tell me how this is happening?
    Re: Hot Water recirculating crossover
    We need details but here goes. The pump is on backwards? Did you get a unit that uses the cold line as a return? Lots of things are possible.
      If everything was working fine before, then it could be cross connecting at a fixture with a single handle faucet. Or a check valve was installed in the wrong place or backwards?
        Do you have any Moen fixtures?
