attic bath venting question
  • attic bath venting question
    can i vent the new attic bath(shower, lav, WC) to the existing 3" vent? thanks for the help
    rjherald
    Re: attic bath venting question
    Without seeing your whole house, it is quite likely that a 3" vent to roof would support an additional bathroom. The bigger question is this....the pipe in question....I hope you are not planning to DRAIN that attic bathroom into a VENT pipe coming up from the lower floors.
      House-wise that 3" will take all you can throw at it.How *is* the waste going to be tied in?
        What else is on the vent? Is there a separate drain stack?
          there is a separate 3" waste line that is into the attic that used to be connected to a half bath. so i am fairly confident that i can connect this new bath to the existing drain and vent. thanks for the help
          rjherald
