Code question?
    Re: Code question?
    Sue the concrete company that foundation isn't level.
      Re: Code question?
      Originally posted by plumbworker View Post
      nope
      What a shame,brand new 3"area drain trap primer and all.floor pitched 1/4" . Condensate
      will be lonely. There is a 30" alley way to the next home. Hope no one gets burned,If it pops off.!
        Re: Code question?
        huh..? your not piping it to the FD??
          Re: Code question?
          What is FD.? footing drain? Existing 1933 footings ,no sub drainage. Out the wall and 6"off the ground in Marin Co .Looked at S.F. amendments. No mention ,so UPC right?
            Re: Code question?
            yeah i would just follow the upc 6" in sf you can pipe it to a floor drain or floor sink w air gap in basements etc.
              Re: Code question?
              Jobs in Noe valley I'll ask Steve the insp. Thank You
                Re: Code question?
                Ok Mark,I give up ! Whats the story with the upside down house??
                • #23
                  Re: Code question?
                  http://freshome.com/2007/09/08/amazi...de-down-house/
                  • #24
                    Re: Code question?
                    thanks Mark ,that is wild
                    • #25
                      Re: Code question?
                      Around here it is okay to pipe the t&p to the floor of the garage if there is a step between the garage and the entry to the home. Meaning that if it were to leak there would not be secondary damage in the home! Otherwise it would have to be piped outside with an approved piping material which can be pex in some areas and not in others. Seems to be some eye-brow raising with the pex fittings that fit inside of pex with the crimp ring as to whether or not you are reducing the size. The code seems to be based on pipe sizes not true dimensions. As long as you used a 3/4 line you would use a 3/4 fitting and everything is 3/4, but the actual bore of that fitting is prob 1/2-5/8". Doesn't see as though it would matter to me. Even the reduction in size will flow more than the t&p fully open. Most inspectors argue that if you use pex coming in then you have not reduced the inlet size. Others are concerned about temps, but the manuf. don't rate the temp without pressure so there is no validity there. T&P should not be pressurized so i would think that it could handle the temp pretty easily? Again, its up to the code official for interpretation. I like black and white. Things like this annoy me.
                      • #26
                        Re: Code question?
                        We cannot use PEX or anything flexible like soft copper for t&p's. I think that they worry about it getting kinked or pinched.
                        So it is hard copper, cpvc or galvanized.
                        • #27
                          Re: Code question?
                          Ditto for MN and when cpvc is used that must be strapped down to the heater.
                          • #28
                            Re: Code question?
                            2003 IPC: "The relief valve discharge shall terminate full size to a safe place of disposal such as the floor, outside the building, or an indirect waste receptor."
                            • #29
                              Re: Code question?
                              Uh oh... Different inspector different interpretation. same town same code.
                              The water heater is located in an outside laundry room on a concrete floor. So I ran the t&p to 6" above the floor. Now the inspector wants a pan under the heater. HUH UPC says "shall not discharge into a pan".
                              Must be evaluation time and the inspector has'nt red tagged enough.
                              • #30
                                Re: Code question?
                                It's stronger than that, it says it is prohibited. If it were me I would challenge him on it.
