joining 2 in to 4 in
  • joining 2 in to 4 in
    I want to run a 2 in pvc washing line inside an old 4 in cast iron toilet drain. There is no hub on the 4 in. Is there a gasket that will fit inside the 4 in that will accept the 2 in pvc? I do not want to use a no-hub connector due to grade issues on a planned concrete pour. I tried a 4x3 rubber hub bushing. Fit inside the cast iron perfectly, but was too tight to accept the 3x2 pvc fitting.
    Steve
    Re: joining 2 in to 4 in
    If you are going to pour concreet, why not break it out around the closet bend and make the proper conection...
    remember the washer will need a p trap and be with in 8ft of a vent
      upc is 5' does 8' fall under the ipc?
        With a deep seal trap we can go 8 ft . 5 ft with a normal trap.
          Keep in mind on day this 4" line is going to back up so you will want a good sized clean out to snake the build up from this line.Otherwise once this plugs up you will be re-cleaning often with a small access.
          So your are going to be doing a concrete pour,why not break up the floor and cut the line and just use a no-hub (mission style with a stainless steel band around it) adapter fitting to change from cast to plastic?
          This toilet you are tying into..Is there a 2" vent coming up near by?This would be an easy alternative with no toilet there and give you and instant proper vent.
