Commercial toilet in house
  • Commercial toilet in house
    Ive always wondered, what would be required to put a tankless commercial type toilet in a house. I know the water pressure isnt sufficient in a home to do this, but is that the only obstacle?
    Re: Commercial toilet in house
    All you need is a 1" water line to the toilet and your ready to hook it up
      A 1" water line is needed for the flush valve, but it was not uncommon for us to run an 1 1/2 service and 1 1/2 or 1 1/4 branch lines. I have seen some of these toilets starve for water on 1''. A lot will depend on pressure as well as length of runs and fixtures. There is usually a lot of noise generated by these toilets so the first thing you want to do is take your wife on a little date over to the gas station to take one of these for a test drive. After she says no way, your problem will be solved.
        Just finished a repair at a church, mens and womans commercial bathrooms.
        3/4" feed to the building!!Was bumped up to 2"after the meter.
          Haha, like she has a say in it....
            Originally posted by JCsPlumbing
            You can put a well pressure tank dedicated to the toilet. Check valve it on the inlet side. Then you have a dedicated pressurized reserve for the toilet/flushvalve.
            I am on a well, so if I ever do decide to do this thats the way I will have to go. Anyone tell me how much one of these toilets runs?
              A Pro Flo brand from Ferguson can be bought as cheap as $65.00. Then add $15.00 for a seat, and $150.00 for a good Sloan Royal flush valve.
                Hmm, never thought about the fact that the toilet and valve are separate, but it makes since. I may have to go that option when I build the house.
                  You could just run a Pressure assist ...All the Noise and Power you Crave
                  They even Blow TP to shards ! (which some can stay behind)
                  Dave
                    Dave
                    part of the reason I want to go with a commercial is because they are alot more reliable. I replace internals in at least two toilets a week and NONE of them are over 4 years old. I also think the look would be sweet.
                      i have 2 pressure assist toilets at my house. both are 15 years old and i never touched them. no plunger, no parts.
                      1 of them i just replaced to make room for a bidet seat
                        Speaking of which, I installed a toilet the other day that the customer went and bought. It was from Home Depot and had no flapper or anything similar. It had a bucket attached to the handle that filled up and then when you hit the handle it dumped the bucket. Is this new, anyone else seen this?
                          it's called a "niagra" like niagra falls
                          been around almost since day 1. early 90's.
                          modified fluidmaster ballcock. it's the trip/ tilt handles that break.
                            Is that 1890s or 1990s Rick?
                              low flow 1.6 has been required since 1990 here.
                              first job i was exposed to them was a mere 900+ toilets.
