sump pump keeps running
  • sump pump keeps running
    I have a sump pump in the basement that is working properly to drain the tank, but when it gets to the bottom, it just gurgles and continues to run and run. If I pound on the pipe it stops the pump, but once the tank fills again it keeps running. I believe it is a Rigid Pump and it does not seem to have a float. just a small black round box attached to the pump that has a cord coming out of it? Can anyone help?
    Re: sump pump keeps running
    It is malfunctioning...replace it while it still will pump. Rain will continue the rest of the day. Good Luck!
      What do you recommend as the best brand to get?
        We use Zoeller pumps, You can pick one up at sears for about $120
        ________
        Honda cbr1100xx specifications
        Mike
          Thanks,
          I have heard great things about Zoeller. Do you think there is anything I can do to get the pump to stop running, in the mean time? or do I just keep hitting it??
