cutting 6" pipe?
  • cutting 6" pipe?
    If you needed to cut some steel 6" pipe with a, wall thickness of about 10 gage, (1/8" approximately), and wanted nice cuts, (to be welded), (straight cuts). most of the pipe is in 40 foot lengths currently.
    what would you suggest to use?
    Re: cutting 6" pipe?
    A slow cutting radial arm band saw, with water/oil lubrication.
    Cuts take a long time but the finished cut is clean.
    Of course, I just mentioned something in the thousands.
    Plasma cutter followed up with a grinder? Lots of work though.
      I'm a welder with all the toys. I have an automatic band saw with oiler.
      Eat Your heart out .
        i
        Have a Hypertherm power max 600 plasma It cuts 3/4" steel clean. I'm bragging , why not?
          metal cutting chop saw, i know my makita will do 6", I have used it for ductile iron before
            for a nice straight cut that will butt and still leave a little bevel for welding.
            a ridgid pipe cutter will do a very clean and straight cut. 1/8'' wall is pretty thin for 6'' pipe, so i doubt it will really strain you. model 6-s or hinged model 466s.
            how many cuts and what size pieces.
            for a couple thousand you can buy their cutter that is powered by a 700 threader. model 258.
            of course a plasma cutter is fast and easy, but not the easiest to cut bevels around the pipe without a motorized roller.
              I currently have 1200' feet of it and want to cut in to about 7' to 8' foot lengths, for a farm project, or at lest some guessing about half of it, of it, into 7 to 8 foot lengths, not all of it will be used on this project, I want to use it in some fencing and corrals the pipe was free (actual payed some to move it), some will be welded and some will not be,
              leaning towards the model 6-s , but to work a 40 foot pipe on to a stationary saw would not be that easy, the model 6-s would let me use the forks to lift it and then cut it,
              what number is the makita saw you were talking about?
              I guess I could make a 20" cut off saw, that I could set up in the shop yard and some stands that would let one feed the pipe into it, (jsut thinking here), possibly someting like in the picture, below,
              http://www.kalamazooindustries.com/abrasive_saws.asp
              K20SSF 20" Abrasive Saw
              20" abrasive wheel,( not included).
              Rugged cast iron trunnion and arm.
              Super rigid, super accurate.
              Heavy-duty guards, efficient spark chute.
              Fast, foot-operated chain vise.
              1" wheel arbor. Sealed ball bearings.
              Table 18" wide x 30" deep.
              Capacity 4" solid, 6" shapes.
              2500 spindle RPM.
              Optional work stop (WL-20). Optional: Power down feed # PH-20
              Optional dust collector (DCV-1), Oscillation #OSC-26
              Dimensions - L 41" x W 24" x H 55"
              15 HP TEFC saw duty motor, 3 phase (220V)
              Magnetic starter, adjustable down stop, less abrasive wheel.
                ill have to look next time i go to the shop, ill look tommorrow for you, how about a demo saw? will it not cut it straight enough?
                  I would cut with a gas axe and finish with a 5" grinder.
                    currently I am looking for ideas and then the budget for the project, which is not that great,
                    Besides a torch I have little to cut that large of pipe on hand, and I hate to say it but I am not that steady with a torch any more, never have ran one well for some reason, unless I have some type of guide to follow, My son can cut with one and it ends up nearly as smooth as a saw cut, but my torch cuts leave some to be desired,
                      I would use a chop saw with a metal blade and rotate the pipe. I use a chop saw to cut 2" steel pipe all the time, works fine, costs squat.
                        Of course ,I've got a chop saw. Don't use it much. It's so LOUD ! I Already wear 2 hearing aids , Ain't got room for 3
                          six inch hing cutters will work wonders for ya. Just be sure to get ridgid or reed and not the chicom one that are on ebay, they don't track.
                          G3
                          http://cgi.ebay.com/H8S-REED-03140-P...3A2%7C294%3A50
                          http://cgi.ebay.com/Ridgid-No-468-Hi...3A5%7C294%3A50
                          these are a couple on ebay now
                          G3
                            I want to thank ever one who has given an idea and or suggestions, thank you again,
                              If you were doing pipe fab work then I would say look into a Wachs cutter. But it sounds like you want to chop up some long lengths of irrigation pipe for use as fence posts, braces, and what not.
                              Can't remember the name of the maker but since you have a torch rig already maybe look for a oxy-acetylene pipe cutting/beveling rig. It sits on the pipe and you can manually (on the lower priced models) crank the torch around and make nice square cuts or bevels in prep for welding.
                              This is a motorized model that follows a chain track, not cheap.
                              There are similar units that are moved manually and less expensive.
                              Actually as ingenious as you are you could probably whip one up for yourself in a weekend that uses your current torch.
