Drain Field Problem
    Re: Drain Field Problem
    Ace Sewer"is your tank at a low elevation and waste gets to the tank by gravity and the lift station is after the tank and the pump(s) throw effluent up to the field?"This is my system, but I beleive all my drain pipe is 4" perf. Unless it is reduced after the 4" makes the turn to go into the drain field from the D-Box. I will try to find out from the installer.
    Thanks, Paul
    "Corripe Cervisiam"
