How Do I Find Possible Underground Drain Pipe Leak
  • How Do I Find Possible Underground Drain Pipe Leak
    Used a drain snake to clear a possible soap clog in basement shower drain.
    It is possible that I punched hole in drain pipe because a LOT of rust came up when I pulled the snake back out of the drain.
    How can I find out if I did indeed punch a hole in the pipe.
    Thanks
    Re: How Do I Find Possible Underground Drain Pipe Leak
    Have someone inspect the line with a camera, its possible you just removed built up scale on the inside of the pipe especially if they are galvanized.
