Why
  • Why
    I have a '''why" question--mostly curiosity. Why do urinals (in public places, stores, etc.) have either a 3/4" or 1" supply to the valve and then just 1/2" to the fixture itself?
    Re: Why
    To give us something to think about while were trying to pee, so we don't get stage fright from thinkin' the guy next to us is taking a peek?
      Re: Why
      does this type of thing happen up north a lot Gene
        Re: Why
        Only when I hang out at the rest areas at night.
        OOOPS.. did I just say that out loud???
          Re: Why
          Oh Gene! Your such a brute!!!!
            Re: Why
            and i thought i was twisted.
            i worked on them but never really thought about it.
            good question.
            Vince
              Re: Why
              It is for the flow required to operate the valve and flush the urinal. We have to install a minimum 1" line for a urinal but I wonder if that will change with all of the new low/no flush urinals.
                Re: Why
                it's for the flush valve. needs more volume since the urinal does not flush by gravity like a traditional toilet would.
                  Re: Why
                  If the green nazi's have their way we will be using waterless urinals before long.
                  Bring on the drain cleaners after these messes are installed!
                  Description
                  Duravit Architec McDry Waterless Urinal (0844360092), White
                  Duravit's sophisticated European bath fixtures offer world-class design features that can turn any bathroom into a bath suite. Duravit's German designed products are distinctive, award winning, and comply with the highest demands of shape, color and function.
                  The McDry flushless urinal features a sealing liquid that has a specific gravity lighter than urine that keeps odors away. McDry's droplet shape prevents dirt from building up, and is completely contact-free for the user.
                  Oooooooookay.
                    Re: Why
                    those urinals make the whole restrooms smell like old piss, and that is worse than crap or grease.
                      Re: Why
                      Why not just put a portalet in there instead, its waterless.
                        Re: Why
                        mark, joey is correcting you, but she's not near the computer
                        joey says that most urinals require 3/4'' to the valve and toilets require 1''.
                        i told her the sloan 186 with 3/4'' tailpiece is 3/4''.
                        but the sloan 180 with 1.25'' tailpiece is 1''.
                        this use to screw us up as it wasn't always specified as to which urinal was being installed and 3/4'' was typical. we would just swap the wall valve to the 3/4'' if it was a #180 flushometer. or swap the tailpiece on a 186 to 1.25''.
                        both ways work fine as there was always enough water volume. you literally needed to open the check stop 1 turn. beyond that you would wash your privates
                        here is a good sloan link for some options.
                        http://www.sloanvalve.com/installationinstr/0816312.pdf
                          Re: Why
                          Tell Joey I stand corrected, the water closets are 40 FU but the urinals are only 20 FU. There was a time when the UPC did not differentiate between a water closet and a urinal they just said flushometer valves for water closets and similar... so they were sized the same.
                            Re: Why
                            mark, you owe it to her to call her yourself
                            you might need to explain it first
                              Re: Why
                              Too late I've already talked to her and she told me all of your secrets.
