Advise on Navitrack and transmitter.
  • Advise on Navitrack and transmitter.
    I would like some input about best frequencies for tracing copper under slab, best point of connection, grounding, and crossfeeding into electrical lines.
    Re: Advise on Navitrack and transmitter.
    Try looking into Dynatel,google it might help.I have used it to locate
    underground faults on electric,but it can be used locate copper pipe.
    If you attach you locator to the water service disconnect the ground
    that is on the service leading back to the main panel.
      Please be careful when you do this. Keep a couple of connectors in your truck in case you break one taking it off. It is very important to reestablish this connection when you are done locating to maintain the integrety of the electrical service.
